All Things Mk5 => Performance Modifications => Modifications & Technical Area => Superchips Zone => Topic started by: dave on October 01, 2012, 10:23:13 am
Title: Stage 2 bluefin K03 4500 flat spot dyno graph inside!
Post by: dave on October 01, 2012, 10:23:13 am
Right to continue from my other thread i was at Falkland performance on saturday and got it rolling roaded and logged on VAGCOM no faults and the fuel presssure was spot on too! Ive  added autotech HPFP internals to my spec and as such it hasnt helped obviously.
Pictures of dyno graph below as you can see it looks spot on until 4500 ish then boom it dies off and tries to recover but just cant this only happens in 4th 5th and 6th and since ive installed stage 2 bluefin.
Anyone have any ideas Kev had me in the car on the rollers keeping an eye on fuel pressures on VAGCOM whilst he dynoed at and the pressure was holding spot on. Only thing we did notice was the reading for the fuel pressure regulator dropped to 0 when it hits the flat spot then it starts to rise again when the car picks up again.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fvv329%2Fdavegsi%2F242127_10152012596730021_900868920_o.jpg&hash=0e309596d0626473f422d3f44962fb637102ccb6)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fvv329%2Fdavegsi%2F616080_10152012597245021_994563823_o.jpg&hash=986c33fdceb954c565f8ed5eff855ce52e658f89)
Title: Re: Stage 2 bluefin K03 4500 flat spot dyno graph inside!
Post by: dave on October 02, 2012, 08:07:28 pm
No one?
Post by: PDT on October 11, 2012, 09:54:12 pm
What is the purple line on the graph?
Post by: PDT on October 11, 2012, 09:55:05 pm
Can you log blocks 020, 114, 115?
Post by: dave on October 11, 2012, 09:57:40 pm
purple line is boost and i dont have vagcom to do any logs unfortunatly
Post by: 56OctyVRS on October 25, 2012, 11:55:04 am
My bet is that your fuel pressure regulator valve is cracking open too soon. It might be worth replacing with one from the rs4 as it doesnt open till 136 bar. Whereas the standard one opens at 130 bar. But if its worn it will open sooner.
Post by: dave on October 25, 2012, 02:57:57 pm
Kind of got this sorted but still has slight flat spot changed map yet again think I'm on number 6 or 7 now
Post by: 56OctyVRS on November 08, 2012, 10:43:18 pm
I had a flat spot at about 5200rpms but since changing the fuel pressure regulator valve to one from as rs4 it has gone.
Post by: dave on November 08, 2012, 11:54:28 pm
You got a part number for that buddy?
Post by: 56OctyVRS on November 09, 2012, 07:32:42 am
Yes mate the part numner is 079130757.
Post by: Baz300 on November 15, 2012, 09:27:55 am
Only 240bhp from a claimed 260bhp from superchips?
I'm on stage 2 but had to get it toned down as the standard pump could not deliver enough fuel
I have a flat spot too with the toned down map but looking at your dyno map I may be going revo soon
Post by: dave on November 15, 2012, 04:00:09 pm
Baz if you have a look at my map its not a flat spot more of a loss of power as soon as it hit 4500! So I was making 245 bhp at 4500rpm. I have a revised map from them and its better but not perfect so I've left it now and I am going to see dave at PDT next year to get it custom mapped instead of pissing about with plug and play stuff
Post by: rtechniki on November 15, 2012, 08:47:53 pm
Looks like cut due to fuel "trims" exceeding +10% could be LPFP fault or blocked filter  you need to log short term fuel trims to see whats going on.
Or it could be a bosch torque reduction routine beccause they have left one of the load axis set stock.
But to pin pint the issues you really need to spend an hour or 2 logging the ecu
Nick
