All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: nadlad on October 13, 2012, 11:22:49 am
Hi all,
After my audio upgrade (three ways at the front) i have a lot of panel rattles been looking on ebay abd found this stuff to deaden the door cards with as that is what is rattling!
I found this stuff on ebay its priced reasonable 10 sheets only 2mm thick 20 quid delivered or shall i get the skinz stuff off squeek in essense you get 3 more sheets from the link one but then again skinz is probably better and 10 pound more am also conscience of adding too much weight to the doors they already feel heavy hence why the ebay one looked good for the price and thickness of 2mm
http://www.ebay.co.uk/itm/CAR-VAN-VEHICLE-SOUND-DEADENING-PROOFING-PADS-SHEETS-10-/220649059457?pt=UK_Body_Shop_Supplies_Paint&hash=item335fb57481
any thoughts
We should have gone ahead and fitted more Skinz sheets to the door cards as I mentioned before that I was going to do on my car. Just unfortunate your budget didn't stretch that far then. I can get you some Skinz mate. Will call you to discuss how to best go about sorting out the rattles / resonance in the door cards. Still need to find some time to do mine too. Not so much rattles, I expect, as resonance from the bass in the doors, lol.
The link you posted looks like the standard stuff they put in cars from the factory. Skinz will give better dampening of the resonance which is what you ideally want to do.
