All Things Mk5 => Mk5 General Area => Topic started by: berg on October 18, 2012, 09:46:51 am
Title: Fitting Forge Silicone Throttle Body Hose...
Post by: berg on October 18, 2012, 09:46:51 am
Bought the full set of Forge hoses off GNJ on here.
Now, is the throttle body one a PITA to fit or am i just a great big gay bear?
Looked like loads of the injection system and maybe even the front bumper need to come off?  :confused: :scared:
Title: Re: Fitting Forge Silicone Throttle Body Hose...
Post by: scopes on October 18, 2012, 09:52:27 am
I wouldnt say it was to easy, bit of a pain in the ass, more fiddly, but no need for the front bumper to come off  :happy2:
There is not to much room in round there to get moving, you can do it!  :jumpmove:
Post by: scopes on October 18, 2012, 10:12:13 am
Better working from underneath it :happy2:
Post by: berg on October 18, 2012, 10:26:49 am
so needs to be on a ramp really? did you do this mod scopes?
Post by: gazon69 on October 18, 2012, 11:04:26 am
It is a barsteward but i did mine on a set on ramps at home. Good luck :happy2:
Post by: sub39h on October 18, 2012, 11:54:07 am
vRSAlex replaced my TB from underneath whilst it was on a ramp.
Post by: berg on October 18, 2012, 12:24:54 pm
ok, well car is in at pipewerx today for master cylinder to be changed so will see what they say about it
Post by: scopes on October 18, 2012, 12:25:36 pm
Yes matey, up on axle stands, removed the throttle body pipe, added new rubber hose on & refitted the TB pipe. As far as i remember you would need to remove the DV, if yours is at the front to tighten & Loosen the clip, thats attached to the engine... Just to give easier access.
Hope that helps!  :happy2:
