All Things Mk5 => Mk5 General Area => Topic started by: s2martyn on November 07, 2012, 11:47:44 pm
Title: oil filter housing
Post by: s2martyn on November 07, 2012, 11:47:44 pm
tightening up the filter today and CRACK,now is this lickely to be the part the filter sits in or the housing thats attached to the block,i could see oil ousing out but was too dark to confirm which...anyone else had the same issue??
Title: Re: oil filter housing
Post by: andygo on November 08, 2012, 09:33:06 am
The plastic housing on my ed30 cracked whilst attempting to undo it with a socket.
It's great design (plastic FFA) meant I had to buy a new one.
About £35 iirc.
Post by: biffobear on November 08, 2012, 03:46:00 pm
is there a part number for it?
Post by: SteveyD on November 08, 2012, 10:43:06 pm
Am I right in saying someone makes an alloy replacement APR or neuspeed rings a bell... Plastic housing + heat into metal thread = cheap fail!
Post by: andygo on November 09, 2012, 02:44:08 pm
06D 115 408 B  filter housing
Post by: njdudsbury on November 09, 2012, 04:37:38 pm
I did exactly the same cracked around the hexagon. Its a real bitch to get off if you have nipped it as there is no space to get in. Have you got it off? I paid about £40 for a new plastic one.
Post by: s2martyn on November 11, 2012, 06:14:00 pm
going to remove it tommorrow to check ,theres a small oil drip now so something has cracked
Post by: njdudsbury on November 13, 2012, 12:21:00 pm
Any news did you get it off?
Post by: Jaywoo-GTI on November 13, 2012, 01:54:47 pm
Even VW technicians manage to break these as it happened to my car whilst in  for a routine service and i was left with the only courtesy car they had left at the time. Polo diesel non turbo.  :sick:
if you have to buy another may be worth spending a little extra for piece of mind.
http://www.awesomegti.com/ecs-tuning-billet-aluminum-oil-filter-housing-kit-2-0t
Post by: njdudsbury on November 13, 2012, 09:46:07 pm
did the broken / cracked one come off alright?
Post by: njdudsbury on November 16, 2012, 06:28:00 pm
Anybody else broke one?
Post by: s2martyn on November 16, 2012, 06:43:57 pm
got it off ok,split near the threads at the top,i must have over tightened it
Post by: njdudsbury on November 16, 2012, 10:12:01 pm
What the thread that goes in the block or the hexagon you put the socket on?
