All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: berg on November 11, 2012, 04:58:55 pm
Title: 42 Draft Designs Shifter Bushing Kit
Post by: berg on November 11, 2012, 04:58:55 pm
Do these work direct with the Forge quickshifter by replacing the plastic bush? Steve at Statllers recommended them as a good mini mod.
Looks like there are two different kits on Awesme Gti site one for 2008-2009 cars, mine is a 57 reg 08 build so does anyone else have the 08-09 kit on a similiar car?
ta
Title: Re: 42 Draft Designs Shifter Bushing Kit
Post by: E30Dom on November 11, 2012, 05:41:49 pm
Been looking at these aswell, but the ones i need for my '07 car awesome gti don't list...
I need the MY06 ones for some reason... :signLOL:
Post by: Tfsi_Mike on November 11, 2012, 05:44:31 pm
I found them to be a great little mod.  Nice quality direct feel.
I've added Alexs AKS Shifter bracket bushes too to finish it off :)
Post by: vRSAlex on November 11, 2012, 08:08:32 pm
Best thing is to go on the 42dd website and check exactly which kit you need.   Awesome list the part numbers so you can match them up.  Some of the kits have different part numbers but are the same bushes in the pack.  So the mk1 tt kit is the same  as one of the golf kits etc.
Post by: scopes on November 11, 2012, 08:31:07 pm
Hey Alex whats the shifter bracket ?
Post by: Tfsi_Mike on November 11, 2012, 09:03:20 pm
The Bush kit itself;
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FMy_Leon_Cupra%2FMods%2F45B717F6-50E4-4E3B-8DDB-3BF897E589A0-21877-0000065F7AEBE6F6.jpg&hash=a615b9f9540df04948b53187c85d5a65e2017dec)
Fitted here;
 (https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FAKS_Tuning%2FMikes_Leon%2F_MG_3399.jpg&hash=9eaf6e68c40ce25aeb5d963ff550c39dd6a15217)
I havent got a custom gaitor as you dont have these bushes  :evilgrin: :grin:
Post by: berg on November 11, 2012, 09:46:42 pm
will have a gander on their site, cheers
Post by: scopes on November 11, 2012, 11:32:45 pm
Fitted here;
Cheers Mike, your a funny guy!
I'll look in to these as you have them, I take it they do make a difference?
 :party: :party:
Post by: berg on February 10, 2013, 03:43:58 pm
having no luck at all with this mod  :fighting:
got the right kit back from awesome ( i had the right one to start with so was my fault)
fitted front to back bushes.
the side to side fit in the rectangular bush so was looking all good. however, the bush wont fit over the actual pivot pin.
the pin is 10mm in circumference and the hole in the bushing 8mm - :stupid:
anyone else had this problem?
Post by: scopes on February 10, 2013, 03:50:17 pm
Yes had to make the hole bigger to suit lol...
Post by: berg on February 10, 2013, 04:30:18 pm
so you had to drill out the bush, but will the copper not all have gone then  :confused:
Post by: scopes on February 10, 2013, 04:32:47 pm
Not on mine, the hole size had to be increased to fit over my forge short shifter...
but as far as i am aware, the correct size can be got, its just a matter of telling them you have the forge short shifter :happy2:
Post by: Phil_T on February 10, 2013, 04:40:36 pm
Instructions are on their website, Print them off their easy to follow
Post by: berg on February 10, 2013, 04:45:58 pm
cheers, i think 42 draft were aware i had forge though  :confused:
Post by: berg on February 10, 2013, 04:48:31 pm
hi phil, thanks for reply. what so they have instructions to remedy this particular issue....
Post by: berg on February 10, 2013, 06:12:57 pm
right, so think the forge side to side shifter comes with two pins, so have to go and rummage in the garage for the 8mm pin and take off the 10 mm pin, hopefully should then be ok
Post by: berg on February 11, 2013, 09:52:42 pm
spoke to John at 42 Draft he is sending me out some 10mm side to side bushings  :pomppomp:
Post by: scopes on February 11, 2013, 10:09:41 pm
Nice one  :happy2:
