All Things Mk5 => How to Guides / Troubleshooting => Topic started by: taylor on November 11, 2012, 08:30:49 pm
So I've just had a light flash up with low tyre pressure now my ESP light has come on is this normal?
Don't know if its normal but I had a similar problem with mine.it turned out to be the dreaded "brake pressure sensor" problem. I got mine replaced free of charge from VW otherwise it would have cost me over £1k !
Check your tyre pressures and then reset the tyre pressure monitor. This should clear the pressure monitor light and then if the esp light still stays then you will know there is some other problem going on.
Yeah I've just up my tyre pressure as they were a bit low and the ESP light is still on I will have to take it to garage I bought it from as I still have a warranty on it
That sounds like the easiest thing to do :happy2:
a scan is required
Yeah I could do with vag-com scan
Ed you Coming up anywhere near the north east any time soon?
Ah the f**king tyre pressure light has come back on and the tyre pressures are spot on
