All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Clarkee200 on November 14, 2012, 07:31:50 pm
Hi
My rcd510 arrived from ebay today. Can anyone shed any light on the firmware and if I will need a canbus adaptor for my 2005 gti
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fvv6%2Fclarkee200%2F13315719-7648-4675-BFBD-3FD9F2BCB77F-493-000000505C7F07E6.jpg&hash=df608344eed0579287c8416203efbc93fe9571bb)
I would first find out what version gateway you have installed as in all likelyhood you will need an updated one to avoid battery drain.
Most likely will need a new gateway unless you have the sound pack upgrade which has the amp under the passenger seat- my 55 plate does and that seems to turn everything off so no drain.
If you plug in the headunit and hold down the setup button for about 5 to 10 seconds you can then get to the screen that has the system info
