All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Martyboy70 on November 15, 2012, 10:46:47 pm
Is is possible to change when the DSG changes gear ?
I.e can I raise or lower the rpm before it moves to the next gear ?
In D mode the shift timing is controlled by the throttle position/load on the engine.
Only way is a custom remap. I have one. GIAC stage 3 map. You can specify shift points etc to your own requirements in any mode.
