All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: Scrubadub on November 16, 2012, 03:45:57 pm
Title: Chassis notch
Post by: Scrubadub on November 16, 2012, 03:45:57 pm
Need to perform above mod as going air ride.
Anyone done it? Just wanted to know what size tubing to weld in as read conflicting views.
Thanks in advance
Title: Re: Chassis notch
Post by: rich83 on November 16, 2012, 03:49:09 pm
Are you sure you will need to do this? The mk5 has a massive notch anyway!
Post by: Scrubadub on November 16, 2012, 03:52:37 pm
From what I've read stateside, to "lay frame" the driverside will need a notch.
Seen people using 2.5" outer diameter tubing but just wanted tried and tested answer
Post by: rich83 on November 16, 2012, 03:57:43 pm
I would try and avoid it at all costs.
1... insurance complications.
2... chassis rigidity.... you will weaken the crumple zone making it less effective
3... re-sale? who will by a cars that has had the chassis leg chopped into.
Post by: chrisr763 on November 16, 2012, 05:06:23 pm
I know the likes of Plush automotive do this modification as part of the cost when installing air ride to a mk5.
Post by: Scrubadub on November 16, 2012, 09:49:40 pm
I read aslong as the tubing thick enough you will not affect the rigidity of the chassis rail. If anything could make it stronger
Post by: Scrubadub on November 16, 2012, 09:49:55 pm
Post by: rich83 on November 16, 2012, 09:59:18 pm
It wont make it stronger... whoever told you that is wrong.
