All Things Mk5 => Mk5 General Area => Topic started by: Kalpsn2000 on November 21, 2012, 03:05:08 pm
I am looking at REVO stage 1 so want to update my diverter valve.
Firstly, which version should I go for?
What are the part numbers?
What is the new price from the stealers?
06F 145 710 D
As you are on a GTI 200PS, i would advice you get a piston type one.
What in the new price from the stealers?
Yeah im in the same boat....i would also like to know which is best and how much they are.....Link anyone?
06F 145 710 D
Thanks Rich
Any idea on price at the stealers?
Cant remember exactly... but 40-50 quid!
Awesome do the revised type (G?) for a decent price £45ish IIRC.
D on a gti due to heat
G on an Edition 30
Is it this one?
http://www.awesomegti.com/car/vw/golfmk5/oem-2-0t-upgraded-piston-diverter-valve
Would go for the G valve as it seems to hold boost better, get it for the VW main dealer of TPS if I were you.
Revision G Part Number 06F 145 710 G about £40
Revision D Part Number 06H 145 710 D about £55
Is it this one?
That's the piston type one, the Revision D (06H 145 710 D)
Is it this one?
I thought the upgraded one was the G - Piston type and the old version was the D - diaphram type :confused:
From what I can gather Rev G is for ko3 and rev D is for ko4. The old G for ko4 has been replaced by D.
And rev C to Rev G for ko3
Getting confused now!
I will be going to the stealers at the weekend to see what they say/have.
^^^^ G for K04 Turbo'd cars (Edition30/Pirelli) and D for the K03 Turbo'd cars (GTI). Both would be better than the Revision C though.
Hope to clear things up for you.
The Revision C was prone to splitting and has been replaced by the G revision. The early G revisions had a few that split but they released a newer G revision that is more robust and so far none that I know of have failed.
When the C revisions were failing people (including myself) went to the D as it was the best solution on the market at the time. Some went the Forge DV route but for a simple plug and play the D was the best. Now the D revsions have been known to leak, as was proved by RTech Nick. The end of the piston does not have a rubber seal so air can leak by, whereas the G revision has a seal on the end and makes a better seal. The G is designed for both the K03 and K04 GTi variants. The D is from the Audi S3.
Just to confuse you the D has now been replaced by a new C revsion, which is basically a D without the cage around the piston.
Which one to chose will be up to you, as people swear by which ever one they have fitted. Having had the D and G fitted I prefer the G, as the car runs smoother and feels more powerful throughout the rev range. Plus its cheaper by quite a bit and cars running 340bhp are running the valve without any issue.
Hope this makes it a bit clearer for you :happy2:
Thanks for the info :happy2:
