All Things Mk5 => Mk5 General Area => Topic started by: Stig_gti on November 23, 2012, 09:42:04 pm
Title: Porsche brakes
Post by: Stig_gti on November 23, 2012, 09:42:04 pm
Hello guys
What model Porsche brakes would fit the mk5 platform
Title: Re: Porsche brakes
Post by: bacillus on November 23, 2012, 09:56:01 pm
Boxster/Cayman fronts like these http://www.mk5golfgti.co.uk/forum/index.php/topic,56756.0.html
You will also need new carriers that you can get off of DaveB
Post by: sub39h on November 24, 2012, 10:18:22 am
Hello guys
Any in theory. You just need the right brackets and discs. Some choices are better than others, such as the kit linked above. Some go for Boxster S calipers and 330mm discs but my understanding is that the improvement in braking is minimal and not worth the increase in weight. You can also go for the 996 Turbo calipers and 350mm discs
Post by: Tortaruga on November 24, 2012, 10:28:29 am
^^^By that sub I assume you'd say the R32 upgrade isn't worth it either? The Porsche calipers are much lighter than the R32's surely?
Post by: bacillus on November 24, 2012, 10:34:33 am
They are...
Post by: Shorty on November 24, 2012, 10:52:47 am
Them 986 calipers and 312mm discs is meant to be a proper good set up and cheap. I run the 996.351.421 calipers off Boxster/996 rear which are slightly bigger and 330mm discs. Pretty sweet and still cheap set up.
If you want to do any type of track use then i'd want a proper 2 piece bell and rotor set up..
Post by: Stig_gti on November 24, 2012, 10:58:36 am
Ok thanks guys for all ur help
I will be doing it in the next couple of weeks so will keep an eye out for a set.
So 986 boxster or caymen front brakes are best
Post by: sub39h on November 24, 2012, 11:25:55 am
i wouldn't say it's not worth swapping to R32 from GTI, because there is a great improvement in braking (supposedly, i've never driven hard on a car with R32 brakes). but between the Boxster calipers and 312mm discs and Boxster S calipers and 330mm discs i doubt there's much in it. after all, DaveB picked the first option, and i'm sure he did that for a reason.
between the R32 and the Boxster, well i went for the Boxsters. they're more expensive initially, but they look miles better (the calipers - the rotor size is a bit anaemic lol) and if DaveB's tests are anything to go by they're more resistant to fade and lighter whilst providing similar braking ability. to me the lightness was the key. the calipers weigh nothing at all.
