All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Tortaruga on December 04, 2012, 10:44:53 pm
I posted recently about this and thought it was my DV, but I reckon it can't be:
Just driving normally, then on a random occasion there is no boost. No CEL's. Car still drives, but the turbo seems to have been neutered. I assume it must be some sort of limp mode. If I switch the engine off and on again it's fine and boosts normally so it can't be a loose hose or anything mechanical (I assume).
Has happened a few times this week.
Strange one :confused:
N75?
Is it any harder on fuel?
Does seem to be harder on fuel, yes.
Just had a dealer diagnostic. Only fault thrown up was p0234 overboost, which is causing the limp mode.
Would a different N75 version help?? Dealer seems to think I should either accept it or flash back to stock.
Had a read of this?
http://wiki.ross-tech.com/wiki/index.php/16618/P0234/000564
^^^ Dealer said no faults with the N75/N249 and no boost leaks at all.
I think I'll contact my tuner and see if he can tweak the map.
Who are TDR Performance?
^^^Tuner in Ireland.
Google tells me that they are ChippedIre which is the same as ChippedUK.
I wish you luck.
I take it from that response that they're not great...
Not the greatest.
