All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: JigBake on December 05, 2012, 04:58:07 pm
Hi,
I have decided to upgrade my lower engine mount. I will be buying a Vibratechnics fast road one, but was wondering how much work it would be to fit it myself, or should I get a garage to do it? Also is it worth fitting the smaller mount on the other end as well, or should I not bother?
Cheers, Jake.
Subframe off
Old bush out
Put new bush in according to manufactures instructions.
Refit Subframe
Re-align the car.
Is the Vibratechnics lower mount like in my photo?:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FRedRobin_05%2FMods%2FEngineMount_dogbone.jpg&hash=773f4bdb6a49f8bf7a9c1b7dc7f700556c0314ec)
^ If it's like mine, it needs a lot of force to pump it in and you'll need to remove the subframe to do it and also, importantly, renew its bolts.
Yes looks identical to yours. If thats what is involved then I will get it fitted I think. I dont fancy doing that. Have you just had the bigger mount changed? Or did you get thd smaller one done at the front as well?
I fitted a powerflex insert but is pretty crap imho. My Milltek DP is contacting something when wheel spinning and hopping.
Cheers.
I had a THS lower mount fitted and it cost me £40 labour for about an hours work.
Cheers.
....I first had a Powerflex insert supplied by Milltek because of this mounting breakage:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fb308%2FRedRobin_05%2FBrokenExhaustMount.jpg&hash=ea8731f1905b984cf3a69183863d9d500f3c3686)
Then I had a lower engine mount followed very soon after by the other two engine mounts. Reviews and info here:
http://www.mk5golfgti.co.uk/forum/index.php/topic,5082.0.html
http://www.mk5golfgti.co.uk/forum/index.php/topic,6086.0.html
