All Things Mk5 => Mk5 General Area => Topic started by: ianv5 on December 09, 2012, 12:31:42 pm
Looking at some springs for my GTI and just wondered what is the best drop e.g 30mm/45mm etc but I am keeping my 17inch Monzas
, without to much comprise in ride comfort etc. Eibach/H&R??
Any pictures would be good with Golf lowered on 17's
There are a couple of pics in my members ride thread with mine lowered on eibach sportlines. Links in my sig.
Thanks mate, will check itout :happy2:
So where did you get the sportlines from and what is the ride like?
Also what drop did you get looks about right in the picture?
Got them from Demon Tweeks I think. Sure the drop was about 45-50mm.
Ride is fine - almost as if your running standard. Bit firmer but solid in the bends.
Thanks mate, that is quite a low drop :happy2:
Maybe wasn't as much as that to be honest, but not far off it.
It's a 45mm drop for a standard golf or a GT. the GTI sits lower than the others so these will springs will only give YOUR CAR about 30mm MAX.
Mine is on H&R's and sits slightly lower than Eibachs, ride comfort is great, just slightly firmer than stock. No scraping over speed bumps even with 5 adults in.
There's plenty of threads on ride comfort with lowering springs but they all give the same answer.
Gray
What H&R do you have, drop?
Gray
Gray
I think there is only one spring type that H&R do. I bought mine from Larkspeed as they were the cheapest. You get an ACTUAL 30ish mm
Gray
I just had a look and yes they only have 30mm drop. Will give them a go as had had eibachs on my golf v5 and have heard good things on here about H&R's. Thank you.
You want o keep stock dampers?
- Volkswagen OE ('Driver Gear' / 'Volkswagen Zubehör')
- Eibach Pro
NO OTHERS, PERIOD.
Gray
Ok. Thanks for SHARING that INFO about MY CAR. ;-)
Gray
:grin: presuming yours is a GTI, you only get 30mm (ish) from eibachs. If yours was an SE or summat, then 45mm is achievable :happy2:
Bit of emphasising going on here :drinking:
I know. As soon as I typed 45mm I knew it wasn't right but was on my phone so couldn't be bothered checking what the actual drop was. I do think it was slightly more than 30mm though.
