General => Random Chat => Topic started by: andrewparker on December 11, 2012, 05:22:13 pm
Title: Tyre Compressors
Post by: andrewparker on December 11, 2012, 05:22:13 pm
I was wondering whether to buy a 12v tyre compressor for home, just so I don't have to go to the garage to inflate/deflate my tyres. Is this realistic or are these things more for emergency use?
This one caught my eye -
http://lovetyres.com/p/Tyre-Accessories/Electric-Tyre-Compressors/Michelin-12V-Tyre-Inflator-with-Digital-Gauge
Title: Re: Tyre Compressors
Post by: stealthwolf on December 11, 2012, 05:23:56 pm
I have used both a footpump and a tyre inflator and have found both to be inaccurate. I would inflate to just over required psi, then use a gauge to double check the settings. Overinflating means you just need to let a bit of air leak out and recheck rather than having to reconnect the pump.
Post by: Matto on December 11, 2012, 05:28:03 pm
I have a VW compressor that came in the boot with some foam as I didn't have a space saver (have since purchased one) but do the same as Stealth. The gauge on the compressor isn't very accurate so use the compressor to inflate plus saves the leg muscles then check with another gauge I know is accurate.
Post by: Hedge on December 11, 2012, 05:29:35 pm
I use a footpump and a manual gauge.
I wouldn't trust a garage's in built gauge.
Post by: Eddie-NL on December 11, 2012, 06:00:25 pm
http://www.ebay.co.uk/itm/Genuine-Audi-Skoda-Seat-VW-Tyre-Inflator-Compressor-Puncture-Repair-Fluid-/261141279976?pt=LH_DefaultDomain_3&hash=item3ccd3bb4e8
genuine vw compressor and tyre foam
Post by: Matto on December 11, 2012, 06:06:51 pm
Only thing you have to watch is if you still use VW for servicing they kindly remind you that the foam is out of date and want around £50 for a new can. I picked up an 18" space saver delivered for £56 that will never go out of date  :signLOL:
Post by: Eddie-NL on December 11, 2012, 06:09:55 pm
when I had my golf, I had a full size spare and compressor and foam. They never told me my can of foam was out of date, which it was :signLOL:
Post by: PND on December 11, 2012, 08:02:42 pm
I got one of these reduced to £15 in Sainsburys a while back.  Does the job nicely.   :happy2:
AutoCare - Automatic Digital Inflator Air Compressor with Pressure Gauge TMX437 (http://www.ebay.co.uk/itm/AutoCare-Automatic-Digital-Inflator-Air-Compressor-with-Pressure-Gauge-TMX437-/270956007601?pt=UK_Air_Tools_and_Compressors&hash=item3f163c90b1)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi.ebayimg.com%2Ft%2FAutoCare-Automatic-Digital-Inflator-Air-Compressor-with-Pressure-Gauge-TMX437-%2F00%2Fs%2FMTU4N1gxMzk1%2F%24%28KGrHqRHJCoE9rehwC7sBPiD%28me%29gg%7E%7E60_12.JPG&hash=2b26666b33193df4fba73e7c6e7a0d6051d86a96) (http://www.ebay.co.uk/itm/AutoCare-Automatic-Digital-Inflator-Air-Compressor-with-Pressure-Gauge-TMX437-/270956007601?pt=UK_Air_Tools_and_Compressors&hash=item3f163c90b1)
You preset it to your required pressure, connect it, press the button and off it goes.  I found that if you initially set the preset slightly higher than required, then it ends up spot on.
Post by: andrewparker on December 12, 2012, 09:16:32 am
Thanks chaps :happy2:
Think I'll buy a 12V compressor and a manual gauge.
Post by: Kalpsn2000 on December 14, 2012, 10:42:17 am
Regarding gauges, I have this tyre pressure gauge:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fecx.images-amazon.com%2Fimages%2FI%2F31bipRj%252B3OL._SL500_AA300_.jpg&hash=b741e13cb56bd02313247fed88e6131b2c1a9945)
http://www.amazon.co.uk/RACE-PROFESSIONAL-TYRE-PRESSURE-GAUGE/dp/B000VZ8S26/ref=sr_1_2?ie=UTF8&qid=1355481597&sr=8-2
I know its pretty expensive for what it is (even though its a couple of quid cheaper than I bought it for) but the quality is brilliant and is accurate :happy2:
Post by: tony_danza on December 14, 2012, 11:09:18 am
I have one of those, it's super accurate.
Post by: Tortaruga on December 14, 2012, 02:54:53 pm
+1. Good gauge. :happy2:
Post by: garrardrj on December 15, 2012, 10:36:42 am
They make a bloody racket and i have had two and both broke quite quickly . I use a Bicycle Track pump , is alot better then you think it will be , adds psi quite quickly too , alot quicker than a comopressor type thing . Use a handheld gauge to check pressure .
