General => Detailing => Topic started by: Black9 on December 21, 2012, 04:42:38 pm
Hi guys looking for some info...
Want to have both my Golfs detailed and can't justify spending £300+ to have them both done so,
Looking to buy a machine polisher over the festive period and a few products to help me along the way...
First off I'm a novice and have never used a polisher in my life so would want a fairly basic one which is easy to use, any recommendations? I know there's a DA type polisher, any other ones out there?
I have a karcher washer, meguiars clay kit and various wax's both in gel and spray types.. What sort of polish should I be going for?
Will also be buying a snow foam extension for my karcher washer and snow foam mixture. Which one is well priced?
Multiple similar threads very recently so if you have a look down the page, you'll find a few suggestions.
Polisher - d/a or rotary. Former is easier to get to grips with and unlikely to cause damage. Get one with sample polishes and some pads as a kit. Snowfoam lances - the proper ones are made by the same company but sold by different people. I got mine from elite car care.
if you buy a d/a megs 300 and megs microfibre pads are a must for vag paint
With the amount of paint they remove, I'd also get a paint depth gauge if that's the route you plan to go down. I also had to buy four large and four small pads because the pads wore out very quickly.
I've had a look on clean your car and the DAS 6 PRO seems like a good machine but I'm not sure which package to go for... I was thinking the SONUS kit as it comes with all the pads and polishes/sealants I'd need to give the car a full detail. Opinions?
Any recommendations on a snow foam attachment for a Karcher washer
Any of them look good. I'd personally go for Sonus pads and Menzerna polish.
They also do a snowfoam lance which is fine.
Menzerna are perfect for Vag paints :)
Get a das6 pro
Zaino z pc fusion
Hex logic pads
Good starter!!
Scholl polishes/compounds are quality.
hex pads did nothing on my R
Never heard that before??
They're the best I've used. I've tried everything.
Did you use a correct polish/pad combination ???
Try a more abrasive compound or firmer pad.
