All Things Mk5 => How to Guides / Troubleshooting => Topic started by: leetdi22 on December 23, 2012, 05:29:14 pm
Title: mk6 dpf
Post by: leetdi22 on December 23, 2012, 05:29:14 pm
hi guys
can anyone give some advise on this Sunday,23,December,2012,13:18:19:19514
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
                Address 01: Engine       Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 LA    HW: 03L 906 022 G
  Component and/or Version: R4 2,0L EDC G000SG  3893
           Software Coding: 0001072
            Work Shop Code: WSC 83968 152 535048
                      VCID: 6FE65F527ED13660C8F
2 Faults Found:
009315 - Diesel Particle Filter
               P2463 - 000 - Excessive Soot Accumulation - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 5
                    Mileage: 120745 km
                    Time Indication: 0
                    Date: 2102.14.08
                    Time: 12:27:26
             Freeze Frame:
                    RPM: 897 /min
                    Speed: 4.0 km/h
                    Pressure: 326 mbar
                    Hex Value: 0xFF01
                    Temperature: 204.0°C
                    (no units): 35.7
                    Mileage: 0 km
001137 - Exhaust Pressure Sensor 1 (G450)
               P0471 - 000 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 120746 km
                    Time Indication: 0
                    Date: 2102.14.08
                    Time: 12:34:16
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Voltage: 12.31 V
                    Pressure: 326 mbar
                    Pressure: 74 mbar
                    (no units): 0.0
                    Temperature: 31.5°C
Readiness: 1 1 0 0 1
cheers
lee
Title: Re: mk6 dpf
Post by: GrayMK5GTI on December 25, 2012, 09:48:41 pm
Could either be your pressure sensor failing (around £60 to replace)
Or your DPF could be full of cR*p  :surprised:
Looks like you've got VCDS, so you could force it into a regen, or take it for a long drive with the revs above 2500rpm.
That should clear it   :happy2:
Title: Re: mk6 dpf
Post by: leetdi22 on December 25, 2012, 10:39:28 pm
cheers for the reply
fitted new presure sensor yesterday and lights gone off
cheers
lee :happy2:
Title: Re: mk6 dpf
Post by: GrayMK5GTI on December 25, 2012, 10:57:03 pm
Good stuff  :happy2:
Not heard of many probs with the common rail TDI's except the pressure sensor failing, which luckily is a cheap fix
Graeme
Title: Re: mk6 dpf
Post by: PDT on December 26, 2012, 11:25:01 am
If you have vagcom you can reset the calibration for the pressure sensor which also often works. When fitting a new señor Los make sure the dpf pipes that clamp onto it are clear by blowing down them.
Title: Re: mk6 dpf
Post by: leetdi22 on December 26, 2012, 01:20:46 pm
hi
yes i have vagcom can you tell me how to reset the calibration please :smiley:
Title: Re: mk6 dpf
Post by: PDT on December 27, 2012, 03:19:09 pm
Can't remover exact sequence, but go into engine, adaptions, then find differential pressure sensor calibration.
