All Things Mk5 => How to Guides / Troubleshooting => Topic started by: tommygti on January 04, 2013, 02:03:24 am
I have a bsh catch can. How would you recommend cleaning it fully rather than just draining it. I do not want to use any chemicals that will damage the engine as the vapour is returned to the crankcase from the catch can.
Clean with wd40! :happy2:
Get some of this. IMO Best oil and general cleaner I've ever used, evaporates off and leaves no residue. Been using it on engines for years.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjj45%2Fgodsy1969%2FPowerclean_zpsda76d660.jpg&hash=ca76ea8ceb4118865c9d024963b4813045de1db9)
After totally draining mine I rinse/flush it with boiling water then leave it to dry out. :smiley:
X2
Take the catch can off, drain, then spray brake cleaner into it, shake, drain and repeat. The cleaner will evaporate very quickly leaving no waiting.
