All Things Mk5 => Modifications & Technical Area => Cosmetic/Interior Modifications => Topic started by: kam on January 08, 2013, 01:21:13 pm
Hi guys missed this boot pop kit that was sold my another member below are the parts required question is will I need any other parts apart from coding , how easy is it to fit and where does the rubber bump stop( buffer) fit??
OEM Auto boot pop kit consisting of:
6Y0 827 550 C – GAS STRUT (Gas struts strong ones to give lift on boot pop)
1J6 827 439 A – BALL PIN (To replace the old ball pin (that the strut clips on to)
1K8 827 761 C – BUFFER
Thanks for any input.
Fitting guide ;)
10 mins top :happy2:
Boot Pop Kit Part Numbers below, the Bump Stops part number is now D not C. The prices have more than likely increased since I got these parts 6 months ago.
2x Skoda Fabia Gas Struts 6Y0 827 550 C £35.98 inc Vat for the pair
2x Scirocco (sprung) Pump stops 1K8 827 761 D. £9.89 inc Vat for the pair. Bits that you need most!
2x Seat Leon Ball pins 1J6 827 439 A £11.97 inc Vat for the pair.
A "How to" guide on fitting the Boot Pop Kit (includes fitting bump stops).......
http://www.ecstuning.com/stage/edoc/MK5RearHatchPop.pdf
Hope this helps. :happy2:
Just ordered all my bits, Should pick them up monday hopefully.
Did you call dealers direct or buy online if so where's best to go ? I found the struts easy enough but the rest I cannot seem to find online ?
^^^^ You can get the pins and stops from TPS, the VW dealer or even from the Skoda parts seller on eBay where a few peeps have bought the struts from.
I have done mine about a year ago and I am very pleased:
This mod seems not to work very well in the cold... When it is below freezing I can never get the hood to open all the way when first opening it...
What is the difference between D and C?
^^^^ no idea on the difference between the C or D Bump Stops but when I last looked on ETKA for someone it says D has replaced C. Mine are C and work a treat (in the warmer weather).
Other than the parts above and hopefully finding someone to run vag-com close to me on it would I need anything else to achieve a boot pop ? I've heard convenience controls needed or is this only on rare occasions ?
^^^^ just those 3 parts (2 of each) and VCDS, nothing lest required. :happy2:
Mine (with a boot full of shopping :laugh:), works a treat.
[ Invalid YouTube link ]
Many thanks those bits are on there way just need someone with vcds now :happy2:
OT , sorry I know. I am selling my kit next week :)
I was looking at getting this lot next week, any reason why your selling yours?
He's breaking and I believe selling the car and stuff :) :happy2:
