All Things Mk5 => How to Guides / Troubleshooting => Topic started by: screech on January 19, 2013, 08:15:55 pm
Hey guys.
Finally got round to fitting my Xenons today, complete with shutters and levelling.
Everything is working except one shutter, which should just be a connection.
But the one that does work, when I put on main beam, flicks on, but flicks back off after a few seconds, the blue dash light stays on.....
Any ideas?
It may need coding.
using right pin in cecm??
I'm guessing this is OEM, have you tried to get a VCDS scan and see if any controller is not working correctly?
hey guys i wanna raise this thread as it's relevant for my situation..
I have just retrofitted bi-xenons for my golf plus but i cannot get the high beam to work, the shutter simply doesnt kick in. i have measured the power with a voltmeter but it returns 0.00 volts, absolutely nothing. :(
I have checked all wirings and everything is set and wired as it should. i have also coded everything right. The right high beam used to work about 2-5 seconds each time i switched it on but it doesnt work at all now, after i have put in a new afs module in the headlight cause the old module was defective.
Anyone knows something? Here's the status of the CECM:
Friday,15,February,2013,16:12:46:16946
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.LBL
Control Module Part Number: 3C0 937 049 E HW: 3C0 937 049 E
Component and/or Version: Bordnetz-SG H37 1002
Software Coding: AB8B8F2700041800000A00000F000000000B5D035C
Work Shop Code: WSC 12345 785 00200
Additional Info: 5M0955119B Wischer 041106 020 0501
VCID: 2B55C23A8A470240A4E
3 Faults Found:
02394 - Parking Light Left Front (M1)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 88381 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.15 V
ON
ON
OFF
OFF
OFF
02498 - Left Low Beam Reflector Motor (V294)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 88381 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
02499 - Right Low Beam Reflector Motor (V295)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 88381 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
This is worth a read if your stuck,
http://www.myturbodiesel.com/1000q/a5/HID-retrofit-Jetta-a5.htm
Hope it helps.
Thanks mate, i can see that there is a issue where the plug which goes into the CECM can be fully locked while the wires are not fully inserted which can result in no electrical contact.. I will take a look at that :)
Also double check the coding has changed after changing it - plenty been caught out with that error !
can you specify that? Check if the coding has applied? Does that mean i have to open the long coding helper just after i have applied the code or should i switch ign off and then on and have a look?
I do as you said - switch the ignition off then recheck - its those simple mistakes which cause loss of hair!
Keep the thread going if you sort it as there's been plenty problems with this mod!
I tried to check the Bi-xenon wires today. The one in D6 didnt really "catch on" but i managed to bend it a little inside so it could get contact. A5 was fine. Turned on the vehicle but no luck this time either... Checked code, everything were as it should be. Damnit.
When i try to go to the central electronics in VCDS and then do a output test on the high beam it reports "Refused by control module"... could this be software related?
Since I've never undertaken this mod I can only share data I've came across.
I had looked at this link and thought it could be helpful!
http://furmanka.blogspot.co.uk/2007/12/mk5-wiata-ksenonowe-z-samopoziomowaniem.html
Let's know what you think.
Thanks for the link. Unfortunately it's not useful in this matter since it's just the same guide as the others. :/
I may be talking out me arse here but don't you need to tell the car it has xenons fitted in the can gateway installation list?
Have you activated xenons in vcds?
Jas
Hi guys, everything is coded. i have coded "xenon with shutters" in the central electronic and the 55 Xenon range (AFS) is coded as well and works. Only the high beam doesnt work.
