All Things Mk5 => Mk5 General Area => Topic started by: ConeKiller on January 27, 2013, 08:56:09 am
Title: Front arches have rust :( help
Post by: ConeKiller on January 27, 2013, 08:56:09 am
Just washed the car and the front arches have rust bubbles forming  :sick: :sad1:
Ive done a search on here but only 2011 threads come up!
How do I go about tackling VW about this?
Always thought mine was rust free :(
Cheers guys
Title: Re: Front arches have rust :( help
Post by: Bainsy edition 30 on January 27, 2013, 09:00:14 am
I have same problem on my white edition 30.help would be great
Post by: GrayMK5GTI on January 27, 2013, 09:32:54 am
See here: 2yrs of arch rust discussion, last post was last month   :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,21537.0.html
Post by: Andy on January 27, 2013, 09:44:36 am
take it to the dealers and if its got good service history then it should get done under warranty
Post by: ianv5 on January 27, 2013, 12:17:41 pm
When did it need a good service history??
They will take a paint thickness gauge a see if any work has been done previously. If not new wings regardless of service history.
Post by: camfollower on January 27, 2013, 12:19:42 pm
I should know this, but how many years paint warranty do the 2006 models have?  iirc it's 6 years, in which case I'm a bit gutted as I've seen some bubbling on the offside arch this morning. :sad1:
Post by: Nodz on January 27, 2013, 12:32:06 pm
It's a misconception that it is done under warranty, it's actually done as a "goodwill gesture" by VW UK.
Take it to the dealers as most know about it by now, they will take pics and paint depths and send it off to VW UK. Takes roughly 3 weeks and you'll have an answer. Usually it's either 70/30 (you pay the 30%) or totally free
Post by: homesqueeze on January 27, 2013, 04:19:51 pm
Rust warranty is actually 12 years, although, as said above it's always called a goodwill gesture repair on the arches because it is not body perforation. A good dealer service history will actually help at some dealers because otherwise they might say that the car has been neglected and wriggle out of it that way.
Post by: camfollower on January 27, 2013, 04:42:10 pm
I had a Focus MK1 that had problems with the arches bubbling too... not again!  Having had the wheel arch lining of both off, at one stage or another, they are very similar in the way that they rub the arch itself; is this the issue here?
Post by: Neiltdi on January 27, 2013, 04:45:41 pm
When i got mine done he took a reading of the paint depth and he said that it had definetly been repaired before , dodnt have to show any service history and i got a new wing for free and a courtesy car!
Post by: Nodz on January 27, 2013, 04:56:35 pm
No it's the foam on the inside of the arch. It holds moisture and basically rots it from the inside out
Post by: homesqueeze on January 27, 2013, 06:02:41 pm
Think it's a combination of the foam and rubbing. My dealer told me it was due to dirt and water getting in between the arch and the lining causing an abrasive paste that rubbed away at the arch. Others have been told it's the foam. Down to poor design whatever the reason!
Post by: RedRobin on January 27, 2013, 06:12:18 pm
If anyone wants a VW PDF explaining the issue, please PM me your email address  :happy2:
Post by: Bainsy edition 30 on January 27, 2013, 06:21:31 pm
Great ill get it into vw.see what they say
Post by: skard on January 27, 2013, 06:32:01 pm
I have had two mk5's in the last year get this fixed for free with no arguing necessary - if the first dealer is no help, go to a second one.
Post by: Bainsy edition 30 on January 31, 2013, 06:43:01 pm
im going my local smith knight fay tommoro.see what they say
