All Things Mk5 => How to Guides / Troubleshooting => Topic started by: vrod on January 28, 2013, 05:45:19 pm
Hi there.
Hi have retrofitted some VW golf plus (2007) xenon lights with cornering. I have bought the aLWR kit from kufatec and fitted everything together according to the guide.. When i turn the ignition on, i can get a stable Xenon beam from both headlights (although the left parking light does not work). When i turn on the engine lights, i get the "AFS Inoperative" error, and the Xenon beams start flickering like h*ll.
I hook on VCDS and find out that its not coded, but i also see that the AFS controller for the right headlight is not working.
I have connected the can-high on the pin 16 at the red canbus plug above the break pedal, the can-low are connected on the pin 6.
The cable i have to install in the fuse box, goes right to SC13 (fuse 13 as i understood it), but im relaly not sure if this is the right place to install this... The fuse itself is only on 5A and i would rather install it in SC15 where the levelling lights goes in with a 10A fuse.
I hope that you guys can help out with this...
Saturday,26,January,2013,21:44:07:16946
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ7W562997 Mileage: 88150km/54773miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: Not registered 0011
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 KQ HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 9247
Revision: --H06--- Serial number: VWZ7Z0F8200812
Coding: 0000071
Shop #: WSC 00011 888 06946
VCID: 78FF2D760B9179D819C
4 Faults Found:
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 000 - Open Circuit
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 85488 km
Time Indication: 0
Date: 2000.00.00
Time: 06:17:49
Freeze Frame:
RPM: 903 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.82 V
Bin. Bits: 00101111
Temperature: 3.6°C
Bin. Bits: 10110000
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 85488 km
Time Indication: 0
Date: 2000.00.00
Time: 06:17:49
Freeze Frame:
RPM: 903 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.82 V
Bin. Bits: 00101111
Temperature: 3.6°C
Bin. Bits: 10110000
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 000 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 85488 km
Time Indication: 0
Date: 2000.00.00
Time: 06:17:49
Freeze Frame:
RPM: 903 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.82 V
Bin. Bits: 00101111
Temperature: 3.6°C
Bin. Bits: 10110000
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 000 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 85488 km
Time Indication: 0
Date: 2000.00.00
Time: 06:17:49
Freeze Frame:
RPM: 903 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.82 V
Bin. Bits: 00101111
Temperature: 3.6°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021234
Shop #: WSC 01392 785 00200
VCID: 73E51A5A12F71A802CE
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 70EF155663E12198D1C
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005810997
Coding: 098B8F2700041800000A00000F00000000095D035C
Shop #: WSC 00000 785 00200
VCID: 2B55C23A8A470240A4E
Subsystem 1 - Part No: 5M0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 041106 020 0501
Coding: 00038805
Shop #: WSC 00000
6 Faults Found:
02394 - Parking Light Left Front (M1)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 60
Mileage: 86274 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.90 V
ON
ON
OFF
OFF
OFF
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 91
Mileage: 87699 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.40 V
OFF
ON
OFF
OFF
OFF
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 88111 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.85 V
ON
ON
OFF
OFF
OFF
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 88111 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.85 V
ON
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 8
Reset counter: 100
Mileage: 86274 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.90 V
ON
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 19
Reset counter: 100
Mileage: 86274 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.90 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 1D AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0V4KBT
Coding: 0012612
Shop #: WSC 01373 785 00200
VCID: 3D71FC6264339CF00AA
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BD HW: 1K0 953 549 BD
Component: J0527 035 0070
Coding: 0002022
VCID: 75E124421C8304B002A
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 873 B HW: 1K0 920 873 B
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0F8200812
Coding: 0007103
Shop #: WSC 00011 888 96745
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0020
Revision: H04 02 Serial number: 21080602001378
Coding: 3D3F034807009002
VCID: 2F6DD62ABE5F7E60886
2 Faults Found:
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 85
Mileage: 87370 km
Time Indication: 0
Date: 2000.00.00
Time: 07:21:12
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 14
Mileage: 85488 km
Time Indication: 0
Date: 2000.00.00
Time: 21:39:17
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1610
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 C HW: 1T0 035 680 B
Component: RNS-MID H11 1300
Revision: AB001001 Serial number: VWZ6Z7H9307101
Coding: 060004400400000200
Shop #: WSC 00479 211 72823
ASAM Dataset: ------------------------- ------
VCID: 2E53CB2E79557768830
6 Faults Found:
03138 - Input AUX IN
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 100
Mileage: 85488 km
Time Indication: 0
Date: 2000.00.00
Time: 21:43:10
00857 - CD Changer Unit (R41)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 254
Reset counter: 60
Mileage: 85488 km
Time Indication: 0
Date: 2000.00.00
Time: 21:40:14
00856 - Radio Antenna
Freeze Frame:
Fault Priority: 5
Fault Frequency: 217
Reset counter: 100
Mileage: 85488 km
Time Indication: 0
Date: 2000.00.00
Time: 21:40:24
00873 - Bass Speaker Rear Right (R17)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 115
Reset counter: 100
Mileage: 85488 km
Time Indication: 0
Date: 2000.00.00
Time: 21:42:16
00872 - Bass Speaker Rear Left (R15)
Freeze Frame:
Fault Priority: 5
Reset counter: 100
Mileage: 85488 km
Time Indication: 0
Date: 2000.00.00
Time: 21:42:16
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 26
Reset counter: 99
Mileage: 85920 km
Time Indication: 0
Date: 2000.00.00
Time: 20:21:43
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0973
Coding: 0000180
VCID: 387FED764B11B9D8D9C
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
Shop #: WSC 00000 028 00001
VCID: 3467D94657795DB8F54
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 809002005103087F2D04840560084F03E0FC00
VCID: 8305CA9AC257AA00BCE
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000180
VCID: 3979E872701BA0D0262
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 8388607
Subsystem 1 - Part No: 4F0 941 329 C
Component: AFS-Lst.-Modul l 0010
Coding: 00000018
Subsystem 2 - Part No: ID-R fehlt
Component: AFS-Lst.-Modul r ....
Coding: 00000255
5 Faults Found:
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02234 - Right Headlight Power Output Stage (J668)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 6
Fault Frequency: 4
Reset counter: 1
Time Indication: 0
Freeze Frame:
Voltage: 11.64 V
Speed: 0.0 km/h
ABS 1
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
6 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 60
Mileage: 85488 km
Time Indication: 0
Date: 2000.00.00
Time: 21:43:10
Freeze Frame:
Fault Priority: 5
Reset counter: 60
Mileage: 85488 km
Time Indication: 0
Date: 2000.00.00
Time: 21:40:14
Freeze Frame:
Fault Priority: 5
Reset counter: 100
Mileage: 85488 km
Time Indication: 0
Date: 2000.00.00
Time: 21:40:24
Freeze Frame:
Fault Priority: 5
Reset counter: 100
Mileage: 85488 km
Time Indication: 0
Date: 2000.00.00
Time: 21:42:16
Freeze Frame:
Fault Priority: 5
Reset counter: 100
Mileage: 85488 km
Time Indication: 0
Date: 2000.00.00
Time: 21:42:16
Freeze Frame:
Fault Priority: 5
Fault Frequency: 26
Reset counter: 99
Mileage: 85920 km
Time Indication: 0
Date: 2000.00.00
Time: 20:21:43
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 005 0914
Coding: 0000144
Shop #: WSC 01392 785 1012552
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
1 Fault Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
End ---------------------------------------------------------------------
you need to code the gateway properly to start with...
:wink:
This link is well worth a read:-
http://www.myturbodiesel.com/1000q/a5/HID-retrofit-Jetta-a5.htm
Thanks for your replies! I will look at the link! I have coded the gateway installation list to include 55 Xenon range and the Central box to include Bi-Xenon. Anything else that i need?
The golf plus doesnt have a ekstra halogen H7 bulb as the normal golf 5 has :)
Ok, i have been digging deep into elsawin to find some wiring flow diagrams... It looks like that this has to be installed in the SC15 fuse according to elsawin. Theres nothing mentioned about a SC13 fuse which i could actually understand, cause the SC13 fuse is actually used for "Heated water nozzles" according to my car manual... Could this have any impact on this problem? :)
EDIT: I forgot to add that my car manual says that the SC15 fuse goes to the "headlight levelling system".
