All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: PimpinR32 on February 01, 2013, 05:21:23 pm
I am a newbie here, I've read alot of information and am still a little confused and wanted to update my RNS510. However I understand that what firmware you upgrade it to, depends on what firmware you already have? Or can I just download the latest firmware for all units as per the tutorial? My car was first registered in November 2007 on a 58 plate if that helps. I don't have this secret menu when you hold the setup button even for 1 minute, all that shows up is the radio selection AM/FM/DAB. I've not got a VAG COM or VCDS so any help is much appreciated.
Where are you based? Perhaps someone's with vcds can unlock secret menu for you and read what version canbus you have.
I'm based in Essex in the Brentwood area, any assistance is much appreciated!
Im about 15 miles from you, I could scan your car and do the upgrade for you if you want. Latest FW and Maps
That would be awesome if you wouldn't mind? When would be convenient for you? Cheers
PM sent
