All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: rscut on February 24, 2013, 10:53:44 am
I'm currently driving a scirocco and looking to get some mods done and was wondering if golf exhausts fit sciroccos, as loads of Milteks come up on here.
Sciroccos have same exhaust systems as mk6 golf. MK6 golf have 99.9% identical to mk5 so you should be on for a straight swap for mid and rear sections exculding catalyst.
Cheers for the reply! That is helpful, as nothing seems to come up on the roc forums.
:happy2: No worries!
I'm not impressed with the "Roc" Forums :sad1:
Downpipes are pretty much the same across tfsi/tsi models i was running a Golf R Scorpion Sports D.pipe on my Tsi Vrs
Will this fit the roc http://www.mk5golfgti.co.uk/forum/index.php/topic,62712.0.html
Its strange over there....People respond really quickly to some questions, however the majority are ignored!
Which "Roc" forums you guys on about?
Scirocconet for me.
@Chungster did you have any problems on the JKM dyno with your Rocco?
Mine kept going into limp mode as the ABS/ESP wasn't happy that the rear wheels weren't turning. Was quite embarrassing getting dyno runs of 90bhp :grin:
Had to pull a fuse in the end to get it to dyno
rear section will definitly fit.. I dunno about the front but consensus is yes it will :happy2:
bit late to the party, but I have a Milltek cat back from new. When I looked in the box it said fits for Scirocco or MKV. So it should be straight forward enough. I agree with the comments on the roc forum, they're not as good or as fruitful as here.
