All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: Trekmeister on March 03, 2013, 01:11:52 pm
What performance upgrades are recommended following hybrid turbo, remap and clutch on a 140 GT and why?
Sent from my GT-I9300 using Tapatalk 2
Brakes are a must
Got them also :)
Inter cooler
Intercooler and exhaust are the next steps.
Large bore front pipe with de cat also-have you done the back brake as well
No not done back brakes yet!
If you ave done the fronts and you do the backs it just makes the caR more balanced when you are braking
Cylinder head :signLOL:
If you're doing the exhaust, dont do just the front pipe waste of time IMO. Just moves the blockage a bit further down the pipe. So do the lot in one hit.
The stock intercooler can handle the hybrid without too much of an issue, but upgrade just because you want to then either the S3 or Airtech are the ways to go.
After that you're starting to look at bigger injectors and a bolt on replacement turbo. Which look on the Darkside website for details.
Fish
