All Things Mk5 => Mk5 General Area => Topic started by: Pikey Motorsports on March 04, 2013, 12:05:29 am
going to be fitting a full milltek to my ed30 this week myself..
any tips or advice?
will i need any new bolts or a new bolt to go with the new bush supplied or does milltek supply everything needed? will i need any new gaskets turbo/downpipe gasket etc or do they supply everything?
You might need oxy-acetylene.
You should fit a new gasket & bolts where it meets the turbo. For the cost it makes sense and is good practice.
I have no idea if Milltek provide these with their exhausts.
cheers :happy2:
but what would i need that for?
Get a new turbo to exhaust gasket from the dealer, I would get 4 x new nuts too as they might warp when removing.
Spray the turbo to exhaust bolts with wd40 the night before and again when you go to remove them.
http://www.goapr.com/support/APR%20VW_AUDI%20TURBO%20INS5098.pdf
Cheers :happy2:
cheers :happy2:
You might need to heat the area around the bolts to get them out.
:sick: :sick: :sick:
