All Things Mk5 => Modifications & Technical Area => Cosmetic/Interior Modifications => Topic started by: tony_danza on July 21, 2009, 03:31:00 pm
I'm toying with the idea of using a 3 point for track days and the 'Ring - given that it's pretty easy to install/remove as required and I can just push it over the shoulders of the seat and out of the way if I want to use the normal belt for tootling about on the day..
But, where's the best place for anchoring the lower mounting points?? The rear strap can go on the rear's floor seatbelt mounting, the others - the seat runners???
Ideas welcome
EDIT:
Doesn't matter, I've found a better solution.... Mum's the word, review to follow!!
FTmotherf***ingW!
