All Things Mk5 => Mk5 General Area => Topic started by: craig_GTI on March 13, 2013, 11:44:36 am
Title: DV changed.. OMG! But a little help needed.
Post by: craig_GTI on March 13, 2013, 11:44:36 am
Just had my DV changed from an original B (pic below) to a revised G.. As you can see the B DV is split all the way round :/ as I pulled away from the garage it pulled like a train :) really couldn't of imagined the car being any more powerful :) after drivin for about 1 min I gave it some throttle and it dropped right of the boost :( then as if I had no turbo all the way home, then after turnin car off and back on I had boost again for a min then the same happened :/ any ideas? Thanks, Craig.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi271.photobucket.com%2Falbums%2Fjj134%2Fcraig_vts%2F50E2555D-75C5-4C84-85E8-00C658B22548-256-0000002C1C55B4FD.jpg&hash=d71160ad8e716b7bb5ffef1a2f0087b02effe2bf)
Title: Re: DV changed.. OMG! But a little help needed.
Post by: GTI-Ross on March 13, 2013, 11:56:45 am
Your PCV Valve maybe be nackerd as well, did your DV have a lot of oil in / around it?
Post by: craig_GTI on March 13, 2013, 11:59:35 am
Yeah, it wasn't around the diaphragm it was around the plug.. Is this what could be causing it? If so why wasn't it doin this before I changed the DV? Thanks.
Post by: alexmccabe on March 13, 2013, 12:05:43 pm
My DV had some oil around the plug when I changed it. How important is it that the PCV gets changed?
Post by: GTI-Ross on March 13, 2013, 12:20:27 pm
Quite important and it only £35 and 30 mins of your time. Easy way to check it start your engine, then remove your dipstick for 2-5 seconds, if the engine runs rough, your PCV is fine, if it barely changes, then PCV is nakerd.
Post by: alexmccabe on March 13, 2013, 12:24:25 pm
OK, thanks. I'll get on that! I found the part number for it. Don't know if I should get the rubber seal too though.
06F 129 101 N = PCV @ £32.64
There isn't a gasket as such but the orange rubber seal that sits behind it is: -
06F 103 483 E = Seal @ £15.44
Post by: craig_GTI on March 13, 2013, 12:27:43 pm
Just tried this and there was not change at all.. So if I get my PCV changed do you think this will resolve my problem? Any links to PCV kits would be appreciated, thanks.
Post by: GTI-Ross on March 13, 2013, 01:17:09 pm
then yeah its defo a good place to start. In regards to the PCV valve, its best to ring your dealer and find out which revision you need by giving them your reg number, i think most people get revision N.
If you replace that and the issue is still there, get some one in your are to run VCD's on it and highlight the area. But defo do PCV  first, often a main culprit
Post by: craig_GTI on March 13, 2013, 01:18:48 pm
Brilliant, thanks alot for your help  :happy2:
Post by: exodus_ste on March 13, 2013, 01:39:32 pm
Sounds like possibly an overboost of the N75 (i think) valve. Its exactly what happened to me. You will have to check in vcds, mine came back with an error relating to 'boost pressure upper limit exceeded' or something like that. Either way, sounds like a limp mode was triggered.
Post by: craig_GTI on March 13, 2013, 03:07:12 pm
Thanks for the info, if this is the case how was it resolved? Simply by deleting the error?
Post by: exodus_ste on March 13, 2013, 04:57:01 pm
Basically mine was broken, no through general failure though! A 'well known independant VAG garage' broke it  :congrats:
Although it is difficult to find you should be able to see if it has pipes broken off etc..
Its sort of cambelt side quite low down. There was a pipe going to the turbo's actuator which was quite nearby. Worth a punt anyway!
Post by: craig_GTI on March 13, 2013, 05:05:07 pm
Thanks alot  :happy2:
Post by: alexmccabe on March 14, 2013, 09:11:58 am
Just ordered my PCV. £36ish inc. VAT. So not too bad. It was the part number that I listed for a GTi. Can't fit it this weekend as I have to drive to Bristol. Hope things will be OK.
Post by: craig_GTI on March 14, 2013, 10:04:38 am
Did you order from a main dealer? Was this the part number 06F 129 101 N? And was that all you ordered or did you have to order a gasket and hose? Sorry for all the questions :/ haha thanks, craig
Post by: alexmccabe on March 14, 2013, 01:56:03 pm
Yeah that is main dealer. I just ordered the valve. Nothing was said about gasket and hose. I've not read anything about that either.
Post by: GTI-Ross on March 14, 2013, 03:36:44 pm
Yeah sometimes the gasket can be worn, so some people buy a new gasket at the same time just to be sure, think gasket is another £16 or so  :sad1:
Post by: alexmccabe on March 15, 2013, 12:35:31 am
Anyone have a guide on how to replace the PCV? I've tried google, but the only one I can find is for a Honda... Or maybe just a tool list?
Post by: GTI-Ross on March 15, 2013, 08:59:20 am
I do but its on my main PC, PM later and i will send it to you.
Post by: craig_GTI on March 15, 2013, 10:57:43 am
Goin VW today to get PCV bits does anyone have part numbers for the parts for a 2005 GTI please.
PCV; 06F 129 101 N
Gasket; ?
Hose; ?
Thanks, Craig.
Post by: craig_GTI on March 17, 2013, 09:28:32 am
Picked up new PCV valve and gasket and not only did he give me discount when I asked if he had any VW keyrings he said its the last one so its on the house :) brilliant service.. Can anyone confirm the part number for an N75 valve for a 2005 gti? Thanks.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi271.photobucket.com%2Falbums%2Fjj134%2Fcraig_vts%2FF0F2BD69-33D9-4EB5-9B64-A0B29C672C9A-1390-00000230E49E69D5.jpg&hash=7121884f412a1c7be5d76f986f346ba5a3cae16a)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi271.photobucket.com%2Falbums%2Fjj134%2Fcraig_vts%2FFDA5BF45-1949-4F25-A45E-20E95916D503-1390-00000230307CCD17.jpg&hash=4b861ac11eedee75420947e0891b5934e0d134e8)
