All Things Mk5 => How to Guides / Troubleshooting => Topic started by: hakko on April 02, 2013, 07:40:51 pm
Hi Guys,
After buying my car (Year 2007) I noticed that the spare key fob doesn't work. I can use it to manually lock/unlock but not via remote.
This means that if I lose the main key, which the car has been locked with via remote (and alarm armed) then I won't be able to disarm the alarm.
I've had a quick look online and couldn't get any of the guides to work. I have also just replaced the battery, in case.
Is it possible for me to pair the fob to the car or must I bring it to a main dealer?
Cheers.
this is maybe not the same for u but i bought my car last week and only one keyfob worked but as it turned out it was just because the 2 keys were too close to each other :stupid: once separated all was ok
I once had a fob lose sync then refused to resync even though the red LED worked.
You can quickly resync it to your Central Convenience Module if you can get a hold of someone with VCDS.
Hi,
That's an interesting solution, but not working for me i'm afraid. :(
Have a read at this method
http://www.mk5golfgti.co.uk/forum/index.php/topic,43747.msg507639.html#msg507639
