All Things Mk5 => Mk5 General Area => Topic started by: Digger3 on April 02, 2013, 07:46:11 pm
OK as it says in the title really the ABS ESP & tyre-pressure lights came on today, turned the ignition off re-started the car lights cleared, drove about a mile and they came back on again.
The ESP light hasn't come back on driving home from work but the ABS as stayed on for a short distance,now there clear again any ideas, I'm in Brum if anyone can help with VAG-COM ??? :smiley:
this happened to me
needed a new wheel bearing and speed sensor. Had it fixed at an indie for £340 :(
Only annoying thing is that it now happens again so i think another wheel has gone!
Checked to see if anyone is near your location?
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.msg1061.html#msg1061
Thanks ,I've mess, Stealthwolf...
all clear for about 8 miles on route to work this morning, went over a small bump in the road and all three lights back on :confused:
If anyone has any ideas or have had similar symptoms please share,,, oh and still need someone with vag-com local to brum :notworthy:
Bump !
I had same issue was a rear bearing and abs speed sensor I was 41 for sensor and 68 for rear bearing then 30 to fit so not bad at all :-) still got ESP tho :(
