General => Testing and Forum Suggestion Box => Topic started by: Lean on July 28, 2009, 12:09:27 am
Would it be possible to rejig the entire section so that when you go in there the board headings show all the VAG dealers listed as the main header. ie:
VW LEEDS
VW YORK
VW CROYDON
and then under those headings all the threads relevant to that particular dealership?
imo - it would make navigating much easier especially if I wanted to check out a dealer in particular, at the moment it seems a little messy -no offense of course :happy2:
I may have misunderstood but that sounds like a fairly mammoth task! Wouldn't simply doing a Search only in that section give you answers?
Probably not a mammoth task bearing in mind it's not too busy in that section yet. I agree searching is the obvious answer but my perfectionist head says it would work so much better and be more utilised by people if it was laid out that way - for a couple of reasons.
1. More people likely to use it for investigating and they would be able to find the area dealer or indi dealer if it was a simple system ie: VW Dealers/Yorkshire/dealers named
2. It would help people wanting to input info (and vice versa) easier as the headers would show the user straight away and easily which area/dealer stopping the problems that do happen ie: I search for Leeds - nothing shows up because someone put in the thread Yorkshire
Anyway for sure it is not necessary just a thought really eitherway the forum still rocks! :happy2:
as you were. :)
I'm sure that SteveP will do something if he can. I might be entirely wrong in my thinking and hence post.
