All Things Mk5 => Mk5 General Area => Topic started by: Mertyvw on April 07, 2013, 11:21:55 pm
Title: Side Airbag Faults Codes 01217/10128
Post by: Mertyvw on April 07, 2013, 11:21:55 pm
Guys , ive got this fault and i found some answers online
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 2F AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0MHUV9
   Coding: 0012870
   Shop #: WSC 01269 785 00200
   VCID: 377B17C346E89AA0D06
2 Faults Found:
01217 - Side Airbag Igniter; Driver Side (N199)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
01218 - Side Airbag Igniter; Passenger Side (N200)
link http://forums.vwvortex.com/showthread.php?2815467 (http://forums.vwvortex.com/showthread.php?2815467)
Is there another way to do this as in is it still under warranty ? can i get VW to do it. My car is a 55 plate 1.9tdi
Any recommendations is appreciated thanx
Title: Re: Side Airbag Faults Codes 01217/10128
Post by: skard on April 07, 2013, 11:25:07 pm
I did that procedure on my tdi and never had the fault return.
Post by: Mertyvw on April 08, 2013, 12:37:22 am
Ok thanks for that I might go for that you know
Title: Re: Re: Side Airbag Faults Codes 01217/10128
Post by: RetroRaz on April 08, 2013, 12:58:08 am
I had this come up a few week back. I just went under the seat and made sure the yellow clips were all Intact and clipped in.
Scanned and cleared and the light and erroe cleared.
Sent From My Samsung S3
Post by: xjay1337 on April 08, 2013, 09:02:06 am
Clear the fault first and see what happens.. air bag faults are permanent (that meaning, they won't self-clear on their own, you need to clear the fault with a machine).
Post by: danishmkvgti on April 08, 2013, 09:27:24 am
contact oil has solved the errors i have had with the seat airbags, so far no need for soldering  :happy2:
