		All Things Mk5 => Mk5 General Area => Topic started by: gazon69 on April 12, 2013, 10:08:34 pm
				Took out my clocks today, replaced them and now i have the traction light on and tyre pressure monitor. Can anyone advise what i need to go into in vcds please.
				Ignition on, full lock one way, hold it, full lock other way, hold it, straighten up wheels and drive slowly for about 50ft. Lights should go off
 done the lock one way then the other. Power steering then te activated, took it out for a drive and still have those two lights on
				when you say you took your clocks out, did you change them to a different one or did you put the original ones back?
 yes. Changed to another then replaced originals.
				did you get immobiliser active on the computer?
 you got p.m mate
