All Things Mk5 => Mk5 General Area => Topic started by: edd666999 on April 17, 2013, 10:33:38 pm
Title: I want to go from banjo to hose
Post by: edd666999 on April 17, 2013, 10:33:38 pm
(https://www.dropbox.com/s/9k6fikdjwmk0lp3/IMG_7493.jpg)
So is this all I need?
I currently have the old banjo bolt connecting to my fuel pump and want to swap to the newer hose style, is this everything I need?
Title: Re: I want to go from banjo to hose
Post by: bacillus on April 17, 2013, 10:49:42 pm
Ed you don't need everything in that pic.
From memory, you need the uprated fuel rail piping, rubber hose to the hpfp, bamboo connector to swap with your banjo bolt brass connector to hpfp and three vw clips.
I'll try to get you the part numbers.
Post by: bacillus on April 17, 2013, 11:19:41 pm
http://www.seatcupra.net/forums/showpost.php?p=3739130&postcount=11
Post by: edd666999 on April 17, 2013, 11:25:08 pm
So with my tired eyes the picture I posted has everything bar the connector that screws into the pump!
Post by: bacillus on April 17, 2013, 11:31:34 pm
Yup, you still need the brass bamboo connector to swap with the one that's presently screwed into your hpfp for the banjo bolt.
