All Things Mk5 => Mk5 General Area => Topic started by: Mertyvw on April 18, 2013, 08:27:07 pm
Hi guys I've just noticed today that once changing into gears one and two I get this little knock in to the change it only does it in gears 1 and two the rest are fine and also when I drop down from gears it all ok .
Anyone have any ideas of what it could be?
Bump
Bump
Read the intro section on this link
http://www.myturbodiesel.com/1000q/a5/clutch-DMF-replacement-Volkswagen.htm
Common is clutch/flywheel for strange noises!
However, get it on a ramp and see is there's any thing simple first - as the clutch fault is expensive!
Thank you i have actually had the flywheel, the clutch changed andthe gearbox reconditioned last summer. Hopefully it nothing big ill have a read
