All Things Mk5 => Mk5 General Area => Topic started by: rich golf gti mk5 on April 27, 2013, 04:58:42 pm
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
perfect finish
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56
VIN: WVWZZZ1KZ6W003165 Mileage: 128870km/80076miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0001
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 A HW: 1K0 907 115 A
Component: 2.0l R4/4V TFSI G00 0070
Revision: --H01--- Serial number: VWZ7Z0E2173747
Coding: 040300031C070160
Shop #: WSC 00187 210 89766
VCID: 2441A30BE7548338654
3 Faults Found:
001089 - EVAP Emission Control Sys
P0441 - 001 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 128796 km
Time Indication: 0
Date: 2000.00.00
Time: 15:40:58
Freeze Frame:
RPM: 759 /min
Load: 16.9 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 17.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.843 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 128831 km
Time Indication: 0
Date: 2000.00.00
Time: 12:54:26
Freeze Frame:
RPM: 1625 /min
Load: 22.3 %
Speed: 32.0 km/h
Temperature: 47.0°C
Temperature: 13.0°C
Voltage: 14.478 V
000564 - Boost Pressure Regulation
P0234 - 001 - Limit Exceeded (Overboost Condition)
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 128861 km
Time Indication: 0
Date: 2000.00.00
Time: 08:19:27
Freeze Frame:
RPM: 2885 /min
Load: 100.0 %
Speed: 76.0 km/h
Temperature: 16.0°C
Temperature: 7.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.478 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 042 Q HW: 02E 927 770 AD
Component: GSG DSG 070 0925
Revision: 04007000 Serial number: 00000504260321
Coding: 0000020
Shop #: WSC 01279 785 00200
VCID: 214FAA1FF84696100E2
1 Fault Found:
18250 - Please check DTC Memory of Instrument Cluster
P1842 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Reset counter: 1
Mileage: 128843 km
Time Indication: 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0004738
VCID: 40890F9B130CBF1861C
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 70E99F5B632C6F98D1C
2 Faults Found:
00756 - Left Vent Temp Sensor (G150)
010 - Open or Short to Plus
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000001834378
Coding: E68D8F2700041800001400001400000000097F075C
Shop #: WSC 00558 210 00001
VCID: 2B5348378A8A4C40A4E
Subsystem 1 - Part No: 1K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 00558
Subsystem 2 - Part No: 1K0 955 559 R Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 010 1010
Coding: 00207646
Shop #: WSC 00558
2 Faults Found:
00061 - Footwell Lights
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 24
Mileage: 128713 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 24
Mileage: 128713 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 N HW: 1K0 909 605 N
Component: 08 AIRBAG VW8 015 2100
Revision: 03015000 Serial number: 0038ED0DMTT2
Coding: 0012344
VCID: 377B644746C2F8A0D06
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 634 0070
Coding: 0012122
VCID: 77FBA447064238A0106
Part No: XXXXXXXXXXX
Component: E0221 007 0050
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K6 920 962
Component: KOMBIINSTRUMENT VDD 1012
Coding: 0024403
Shop #: WSC 00999 444 64523
VCID: EED50123F918F968430
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
010 - Open or Short to Plus - Intermittent
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 280010551901DE
Coding: 3F0F0340070001
VCID: 2A5D4D33857055485F8
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 31
Reset counter: 24
Mileage: 128713 km
Time Indication: 0
Date: 2000.00.00
Time: 16:53:49
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1012
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 B HW: 1T0 035 680 B
Component: RNS-MID H03 0800
Revision: AB001001 Serial number: VWZ6Z7H7178053
Coding: 040004000400001200
Shop #: WSC 00020 790 00000
ASAM Dataset: ------------------------- ------
VCID: 2D57462F749E4270BAA
2 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 32
Reset counter: 24
Mileage: 128712 km
Time Indication: 0
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 19
Mileage: 128713 km
Time Indication: 0
Date: 2000.00.00
Time: 16:54:39
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2310
Coding: 0000564
VCID: 3665694341C801A8CB0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.1 D04 1606
VCID: 3363505752BA1480ECE
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 18C802487F6D0C0DC85AC65010CC
Shop #: WSC 12345 785 00200
VCID: 78F9A77B0B5C37D819C
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Part No: 1K0 951 177 A
Component: Innenraumueberw.005 0202
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000564
2 Faults Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
012 - Electrical Fault in Circuit - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 32
Reset counter: 24
Mileage: 128712 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 19
Mileage: 128713 km
Time Indication: 0
Date: 2000.00.00
Time: 16:54:39
End ---------------------------------------------------------------------
It will be a bad sensor if over-boost has suddenly shown up. http://www.ecstuning.com/Volkswagen-Golf_V--2.0T/Engine/Electrical/Sensors/Boost_Pressure/
Do you have a boost gauge? If you are creating enough boost then you likely need the boost sensor.
http://wiki.ross-tech.com/wiki/index.php/16618/P0234/000564
