All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: GTI-Ross on May 01, 2013, 04:35:36 pm
Title: RNS510 - can you add a sub woofer to this stereo?
Post by: GTI-Ross on May 01, 2013, 04:35:36 pm
As title says, just looking for info and adding a small sub in the back of my MK6 GTI....Thanks
Title: Re: RNS510 - can you add a sub woofer to this stereo?
Post by: GTI-Ross on May 02, 2013, 08:51:11 am
Anyone?
Title: Re: Re: RNS510 - can you add a sub woofer to this stereo?
Post by: RetroRaz on May 02, 2013, 08:54:51 am
Yes you can. You have to get an adapter that converts the wire from the rear speaker to a phone.  That gives the phono outputs.
And the remote wire ive seen people take from the ciggie lighter on a mk5.  Might be different on a mk6. Power and ground to the amp ad normal.  And I think thats it afaik.
Sent From My Samsung S3
Post by: Squeeguk on May 04, 2013, 11:22:32 am
Or you can get a newer amp with high level speaker inputs which also has the effect of being a remote wire too. You just need to make up a harness from the head unit to the amp or cut the existing wiring.
