All Things Mk5 => Mk5 General Area => Topic started by: TomGTI on May 03, 2013, 06:28:37 pm
Title: Air-con head ache
Post by: TomGTI on May 03, 2013, 06:28:37 pm
I've recentley had my air-con system vacuum tested and regassed and all was fine and I've just changed the cabin filter myself which was filthy but the problem is the air-con isn't cold but the garage I went to said that the air-con pump is kicking in and i can hear a noisey fan working in the engine when the aircon is on but I'm not sure if this is normal.
Has anyone had this problem before or can help me out I could really do with it sorted?
Title: Re: Air-con head ache
Post by: bacillus on May 03, 2013, 07:10:39 pm
Small fan should be working when your AC is turned on.
Post by: TomGTI on May 03, 2013, 07:32:33 pm
Both fans were working but it is a lot noisier when the aircon is on.
I've read there could be some sort of switch which hasn't turned on?
Post by: Type_R on May 03, 2013, 09:28:07 pm
Unfortunately this information is not true.
On the MK4 Golfs the small fan comes on with the A/C but on the MK5 if the ambient temperature is low (I would guess less than 15C) then it does not come on straight away.
I fell into the trap of people telling me that there was something wrong as neither of my fans were coming on with the A/C with ambient temps of 10C. I tested with VCDS, both fans behaved normally. I pulled the fuse and put it back in again, no problems.
Today I started the car with an ambient temp of 16.5C, turned the AC on and the fans turned on at low speed. I asked someone on here to check their MK5 GTi as well and their's behaved exactly like mine. I know that the 2.0 TFSi Audi A3 behaves like mine too, so I doubt there is any evidence to suggest that the 'small fan always comes on with the AC.'
