All Things Mk5 => Mk5 General Area => Topic started by: bigdave1978 on May 11, 2013, 10:01:35 am
Just looking a little advice, my car was in my garage and had not been driven for about 6weeks and I took it out for a drive the other night and on boost there is a puff of blue smoke out the back. So my question is are the k03 turbos prone to blowing the turbo seals and if the turbo seals are gone what's the best route to go down (k04) :wink:
Nobody can help :scared:
chill Winston some one will be along shortly :drinking:
Blue smoke is oil, so could be a faulty PCV (best case), turbo seals or piston rings.
A blow through test of the PCV is worth doing, followed by a compression test to test the bore.
What is your mileage? Is your car using a lot of oil?
Graeme
58000 miles on and it has only started to smoke, dipped the oil and it is low but only half a litre so. How do I test the Pcv ?
You can take the PCV off and try to blow through it both ways. If it's ok, should only be able to blow through it one way.
Thanks for the help I will try this during the week
