All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: holland15h on May 11, 2013, 07:00:48 pm
Title: tdi owners egr valve gasket
Post by: holland15h on May 11, 2013, 07:00:48 pm
Just a quick mention if you didn't know,  there is a gasket from a skoda and seat that restricts the amount of gas fed back in. I put one on my car today as its cheaper than an egr delete . it seams smoother and has a better pick up. The gasket cost me £2.54 from tps. Part number 028131547b. Below is a picture of the difference between the 2,
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fbaz88icf%2FLeon%2FP1010226.jpg&hash=de3fe720a47707caedd9da6470738a066498f16e)
Title: Re: Re: tdi owners egr valve gasket
Post by: Trekmeister on May 11, 2013, 07:23:43 pm
Would it not cause a build up to develop over time causing a blockage?
Title: Re: tdi owners egr valve gasket
Post by: holland15h on May 11, 2013, 07:45:02 pm
Possibly over a long period
Post by: Trekmeister on May 11, 2013, 09:40:01 pm
Apparently you can reduce the amount of gas going through the egr using VCDS.
Post by: Matto on May 11, 2013, 11:28:09 pm
I think this was also a way to stop the stutter the some 170's would suffer with.
Post by: xjay1337 on May 12, 2013, 12:16:14 am
Yeah I believe this is true, if not you can do it as part of a remap, basically set the EGR to constantly be open (as little gas recirculation as possible). You could also just put a solid washer over the return pipe.  :party:
