All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: Jack of Hearts on May 25, 2013, 04:37:31 pm
Hi guys. Had my dsg gti for about a month now, I'm slowly working my way through the car, I've replaced a bit of broken trim I've changed the budget tyres and I've got it in for a service. Now I want to know what should come next? I've read about the cam follower but is there anything else I should also get changed?
Cheers in advance
CAm follower,
diverted valve, used Rev D or G
Pcv
Spark plugs
Oil service
Thanks for the reply :)
Oil service is getting done shortly, I'll add sparks to the list as well.
Cam follower I've seen the how to guides and it looks fairly easy.
What is the difference between the two diverter valves?
Is there vw part numbers for the pcv and the preffured type of diverter valve?
