All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: Samu on May 26, 2013, 10:06:50 am
Title: PCV Valve issue...
Post by: Samu on May 26, 2013, 10:06:50 am
Hi all,
Just got back from being away for 4 weeks, my GTI sounds pretty rough when idling.
I've pulled the dipstick with the car running and the engine noise gets worse.
Would I be right in saying the PCV valve could be the issue?
Any other ideas on what it may be?
Thanks.
Title: Re: PCV Valve issue...
Post by: xjay1337 on May 26, 2013, 08:56:37 pm
Pretty sure from reading that when you pull the oil stick out and the noise gets worse the PCV system is working?
Post by: MC71 on May 27, 2013, 08:27:40 am
^^^^ That's right.  Running rough when dipstick out = PCV is fine although you may as well change it for the latest revision if your concerned.
OP, try changing your Coilpacks, may be the cause.
