All Things Mk5 => Mk5 General Area => Topic started by: Jussa on May 30, 2013, 09:50:21 pm
Title: Please help!!
Post by: Jussa on May 30, 2013, 09:50:21 pm
Driving home from AKS and just as I got home decided to open my window.  The drivers window opens, but I have to keep pushing the button to open it, the one touch function has disappeared, it also won't open the passenger window with a one touch, I have to keep my finger on it  :confused: I leant over to the passenger window, pushed the button and it opened with one touch WTF is going on??????  It seems that the driver side has lost the one touch function to open either window  :sad1:
Any ideas??
Title: Re: Please help!!
Post by: scopes on May 30, 2013, 09:52:11 pm
Was your battery disconnected!
Post by: scopes on May 30, 2013, 09:53:36 pm
If so you need to reset the window memory, by holding the button for the window to go down, and the same for the window to come back up, about 4 or 5 times  :wink:
Hope that helps!
Post by: Jussa on May 30, 2013, 10:09:36 pm
Hi mate it was disconnected  :confused:
What do u mean hold it down?
Do I keep my finger on the button all the way down and all the way up again 5 times?
 :popcornsoda:
Post by: Jonny on May 30, 2013, 10:13:02 pm
Hold the window switch down until it's fully down, then hold it up until the window is all the way up, problem should resolve itself  :happy2:
Post by: Eddie-NL on May 30, 2013, 10:13:03 pm
lower the window and hold the switch down for a few seconds, then raise it and hold the switch for few seconds
Post by: Jussa on May 30, 2013, 10:16:09 pm
Thanks a lot guys, I'll try it in the morning.
What a palava though, unbelievable that this happens after a simple battery disconnection  :fighting:
Post by: scopes on May 30, 2013, 10:16:25 pm
What them guys said ^^^^^
 :jumpmove:
Post by: alexmccabe on May 30, 2013, 10:20:14 pm
If it doesn't work, please tell me what it is. I have the same problem, except only on the right hand side. I'm thinking door module.
Post by: Tortaruga on May 30, 2013, 10:26:29 pm
Yes, this is most likely the problem.
Post by: Jussa on May 30, 2013, 10:37:18 pm
Door module????
Is it expensive, and is it a difficult job??
Post by: Tortaruga on May 30, 2013, 10:43:22 pm
It's about £100 for the unit; there are non-oem ones on ebay for £40, but apparently these are rubbish. Door skin needs to be removed - there's a guide in the 'how to' thread.
The module itself can possibly be repaired if you're prepared to open it up and use a soldering iron to re-establish any broken connections.
Post by: Jussa on May 30, 2013, 10:47:18 pm
Well after this door module malarkey I couldn't sit and relax so I went to the car  :signLOL:
Legendary info guys, that's why I love this forum.
I followed the instructions from Scopes, Eddie and Jonny and its now all good - thanks again guys  :happy2: :drinking: :happy2:
Post by: scopes on May 30, 2013, 10:55:03 pm
no worries man, thank you !
Post by: samdem on May 30, 2013, 11:38:44 pm
my one touch works fine, most of the time. sometimes when i want to put my window up i click up and it goes all the way down  :laugh: very annoying.. at least you dont have to wind it up  :grin:
