All Things Mk5 => Mk5 General Area => Topic started by: phil bert on June 03, 2013, 06:18:01 pm
ok so I been looking for alittle while and I cant spot it so if anybody can point me in the right direction to find the dv that be great or pictues even better , thanks guys
If you mean dump valve ? There isn't one on 2.0tdi pd engine ....only a egr at front of engine
sent using my own fingers
diverter valve ? is what i'm thinking
Can't ever remember a diverter valve ?? Will ask about
Forge use to make and upgraded diverter/recirc valve - think it was about £300 fitted??
Dump valve to atmosphere = bad idea for a diesel (turbo stall!)
Diverter/ recirc valve = no benefit £300 worse off.
You want a tdi to chirp, cut the airbox & a performance filter. Then a cat bypass and a straight through exhaust system!!
My old Fabia VRS sounded amazing
