All Things Mk5 => How to Guides / Troubleshooting => Topic started by: reaper7881 on June 07, 2013, 09:58:31 pm
hi
i just recently purchased a highline speedo, wiper stalk and 3 spoke wheel from ebay
ive got the speedo all coded up and working nicely with the car no problems,
but how to i tell the car that it has a multi-function wiper stalk/ activate the wiper stalk in vcds
thanks :wink:
mk5 golf 1.9 tdi
Hi
What Cluster have you upgraded from?
Have you got a high line steering control module?
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
i did read somewhere some high line clusters work using MFSW.
my old cluster was a midline 1k0 920 951 g
the new highline cluster is 1K0 920 970 L
the black box under the steering wheel says
(https://lh3.googleusercontent.com/-beoJoEyBo68/UbMYBnEDxlI/AAAAAAAAAMM/rys-dHdW2bw/w958-h719-no/IMG_20130607_110429.jpg)
the guy i bought it off had the conversion done by some one and it worked with the wiper stalk
rosstechs website says
1K0-953-549-A Type 1 SW 0030 Midline Yes - -
my car already has cruise control fitted from the factory if that makes any difference
You need to fit the rocker MFA Stalk
and code the module
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000042
Shop #: WSC 00152 210 91233
VCID: 306B1614A338723
No fault code found.
Cruise, rear wiper and Trip computer
thats the thing
i have fitted the multi function wiper stalk but the buttons dont do anything wipers work as normal
what menus do i need to go in to to code the stalk up, are there any tutorials
thanks
Have you have coded your module to 42
if you have the checkthe advanced measuring blocks for the stalk function
ill get my mate with the computer to do it tomorrow
i have no idea whats going on
thanks
it won't work if it is not coded
get it coded and report back
got it all coded up and now its working nicely
are there any hidden menus like the convenience menu that i can activate on the speedo or do i need a new controller for that :wink:
if you want Convenience then you need a MAX version
same for Lights & Vision
whats the part number for the maxx version
i have found a maxx ccm with part number 1K0959433BT 1K0959433AQ
i took a pic of my ccm behind the glove box
(https://lh4.googleusercontent.com/-NfNM0jWAM9w/Uc7RBlzRMqI/AAAAAAAAAP8/01FJzRc7hW4/w958-h719-no/IMG_20130629_125454.jpg)
it says
HELLA KG
made in germany
01.09.04 0562610
5DK 008 583-12 HLO w42 04245 P003 0194
is the 1K0959433BT 1K0959433AQ module compatible with my car
thanks
edit: ah crap the part number is hidden behind the plastic holder thing, back in 5 need to take it apart again
new pic (https://lh3.googleusercontent.com/-ORdlC6scotE/Uc7cvfOuCYI/AAAAAAAAAQM/2IRjz17Yuy0/w607-h809-no/IMG_20130629_135652.jpg)
VW AG 1K0 959 433 BK
KSG Max s2tuere s0301/H02
HELLA KG
made in germany
01.09.04 0562610
