All Things Mk5 => Mk5 General Area => Topic started by: TomGTI on June 25, 2013, 05:05:00 pm
Hey.
I need the plastic strip which runs down the in side just next to the seal and the door lock mechanism on the off side/drivers side door.
Part numbers is 1K3837382D and I need the 1 metal clip for the bottom and the other plug in plastic clips.
Looking to but online.
Thanks you please help :smiley:
Why don't you just order it from a dealer?
Basically its come loose at the bottom and left a mark in the seal and which has rusted and I've also noticed that the rest of the seal had bubbles in it. If I replace the part then go see them maybe they will respair the seal under the paint work warrenty :signLOL:
Doesn't answer why you don't just walk into a dealer and order the part?
They don't inspect your car, they just take your money.
^^^you have a point I'll pick up the part and clips in the morning and get them to check the rust later on in the afternoon :happy2:
