All Things Mk5 => Mk5 General Area => Topic started by: neg on November 30, 2008, 05:51:08 pm
Anyone know how easy it is to remove a coilpack ?
Its too cold to investigate :wink:
Quite simple mate, once you get the engine cover off of course.
Always worth doing it with a warm engine so as to soften up the rubbers.
To remove the coils I normally undo all of the plugs as they are on a rail which makes removing only one more difficult.
Be careful if you try to lever them up as they are fragile.
So sounds like no tools required really then...
http://www.golfmkv.net/blog/archives/9
nice one batman :happy2:
You gotta love those gloves.
Do I need some of those too ... :wink:
Which Cylinder is which?
1 on the left I would imagine.
This is an Audi but it's the same for your GTi. :smiley:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb250%2FAudiFourtitude%2Fforum_pics%2Fplug_numbering.jpg&hash=8ac5fa5d2867bf1d44253e98a054e50cc9daac5c)
Yes as I thought although my left was as you look at it :grin:
Thats what I assumed ... but we know what happens when you ass-u-me :wink:
Cheers guys. Not do I swap it for another cylinder and see if it follows or just replace it - I suppose when removed if really bad you can tell... then I suppose should I swap them all...
If you can mange a full set then it wouldn't hurt.
Plus the new set may be a later revision.
I did hear the later one's dont handle the extra heat caused by remapping - not sure if it came to anything but Revo were investigating something
That's an interesting bit of info...
anyway, I've emailed revo just to check if they actually found anything out or if there is a specific revision I should be getting. Will post up any info and let you know how I get on.
All I need then is a new turbo :sad:
Did I miss something???
I think I'm having similar issues to what Robin had - not boosting properly.
oh well may as well buy a K04 then eh
Coilpacks come out pretty easy - hardest bit was getting the connectors off, one had the clip missing which made it more difficult (that will be the stealer at the last service then when the plugs were changed!).
Also fitted a new coolant tank in the Mk4 to solve the dreaded STOP check coolant error - wonder if the mk5 will eventually have this issue.
