All Things Mk5 => Mk5 General Area => Topic started by: dan_dapper on July 03, 2013, 09:32:29 pm
Title: anyone with expertites on Mobridge
Post by: dan_dapper on July 03, 2013, 09:32:29 pm
Hope someone can help,
Head-UNIT: RNS-510 firmware 2760
mobridge: M1000-C-BT-CAN Bluetooth
I performed a firmware update on my Mobridge as my "call lists/received/missed/dialed" wasn't showing up on the head unit, when I looked on their website it says they had a firmware updates for newer phones, I decided to give it a try using the SD card.
Before the upgrade, everything had been working fine with no problems (Call ID, Phone book, making and receiving calls) except the “call list”.
I am kicking myself now for upgrading it now.
I download the m1000-c-bt-vw_1.4.3.fif &  (GEN 2 )bluetooth_gen2_03.31.08.fif put the files on a memory card. put the SD into the Mobridge, turned on head unit (waited 10 minutes) nothing visually happened.
After turning it off and on, I could no longer see the Mobridge in my bluetooth search so cant connect to it. Repeated the above process. Same as above, I tried using the other (GEN 1) bluetooth_gen1_3.12.fif file listed as this seemed the most logical next step. But still have the same problem.
Here is the output for the txt file created on the SD card
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~This Card was used with a mObridge!
http://www.mobridge-usa.com
Serial Number:   0000000000000000
Software Version: 8 : 0 : 01.04.03
Boot Version: 8 : 01.00.08
Bluetooth Version: 1000 :: 00.00
Configuration:
Vehicle                  : Volkswagen
Mic algorithm            : 4
Mic select               : 0
Mic gain                 : 4
Vol communication        : 15
Vol ring                 : 15
Vol prompt               : 15
Vol streaming            : 63
Bluetooth Pin            : 1234
Bypass switch  : INACTIVE
Please forward any information below to mObridge for support:
can anyone advise?
