All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: Kalpesh on July 09, 2013, 04:57:31 pm
Title: Headlight switch trim panel removal?
Post by: Kalpesh on July 09, 2013, 04:57:31 pm
Hi all,
How do you remove the trim panel that holds the headlight switch and headlight adjuster?
Hope that makes sense  :happy2:
Title: Re: Headlight switch trim panel removal?
Post by: doylebros on July 09, 2013, 08:12:15 pm
This may help
http://www.mk5golfgti.co.uk/forum/index.php/topic,1800.0.html
Post by: Kalpesh on July 09, 2013, 08:29:20 pm
Thanks for the reply
Manger to get the light switch out but it's the panel that holds the switch I need to remove
Post by: rich83 on July 09, 2013, 08:31:01 pm
Theres one screw in the light switch hole.
There is one under the cover on top of the steering wheel
There are two (i think) in the 'roof' of the cubby hole compartment under the light switch
I think thats it
Post by: Kalpesh on July 09, 2013, 08:32:26 pm
Meant managed
Post by: Kalpesh on July 09, 2013, 08:38:59 pm
Cheers for the reply, will give it a go and report back
