All Things Mk5 => Mk5 General Area => Topic started by: Polo6n1600i on July 10, 2013, 04:56:44 pm
I went to my parents yesterday - parked the car on the drive - was there maybe 40 minutes. Found a wet match on the driveway. Thought nothing of it as d been running the a/c & thought it was maybe just the rad with ice on it. Went to parents today to sort out a parcel that arrived - patch is still there!! Check everything over - oil level is fine, brake fluid checks out fine too. Only thing I noticed is that the radiator cap was loose a bit. Could that have caused it?? I've refilled the coolant and retightened the cap. See if it goes loose again
Where abouts is the wet patch in relation to the car?
Towards the back of the front axle, maybe inline with the front bulkhead approx
I suspect this is from using the ac in this weather.
I thought that too - but why does the mark linger??
Don't know but I have a big damp patch on my garage floor because of it. :smiley:
Hmm!!! Investigations continue!!
Cracked washer bottle? Although this would be a lot farther forward. If not A/C, just keep an eye on your fluids...
You can usually tell if it's oil/coolant/brake fluid by colour/smell etc. so which is it?
It didn't really have a smell/feel to it
Most likely condensation.. don't use the AC and I'm sure it would go away.
The washer bottle would be a small leak on the front right of your car infront of the wheel. IE no-where near where the OP reports a problem! :confused:
If it smells of nothing and has no feeling of oil/lubricity then don't worry
As I said.
Ok - investigations continue as leak was getting worse - plus still loosing coolant - think its coming from the water pump now!! Got the car up in the air, undertray off - lots of pinky sticky feeling fluid everywhere!! Just had timing belt and water pump done recently, so it's going back to them this afternoon! :-( just what I didn't need, I'm going on holiday in 2 weeks - plus I'd saved up some money to buy an immaculate mk2 golf GTi 8v - that's now on the rocks!!
could be steering rack fluid?
Nope, there is coolant all over the under tray as well
So it's coolant.
Job done.
The chap has a MK5?
Scary innit :signLOL: :signLOL:
